setting up front coil overs and CC plates..new to this side of things
so i am at the point that i need to get everything set up for an alignment but i need to set my coil over height first and try to get the CC plates alot closer then they are.
coil over question- How are you guys determining how far to set your spring lock nuts on your coil overs? is there an artical that someone could direct me to to understand the differences in adjustment and how they affect the car from a drag car stand point?
CC plates/ alignment question- Who do you recommend downriver to handle the alignment and how much should i expect to pay? will the alignment need to be done every time i make an adjustment? best way to put a rough alignment on it for the shop?
Thank you to everyone in advance!
