do you sell any cool front end limiters for a fox body?
what up
Not to jack your thread Joe..
But most the guys in NMCA N/A Pro Stock take a piece of C stock, box or just gussets made of mild steel. Drill holes in them for roll pins, mount on upper inner wheel well & lower control arm. Then use one inch link chain with 2, 3 or 4 links longer depends on what ya need.
Most of the supplied cable kits broke for most of the guys so this is what alot of them use.
Next time your on the Bullet look up Jeff Chandler he has great picks of his.
Steve ;)
I use a piece of cable that's looped and put over the top of the k-member bolt up top, then it goes through an eye bolt in the tubular a-arm sway bar hole. That way I can adjust the length with the eye bolt depending on the track. If you want pics, let me know and I can email them.
We are working on one that is adjustable from the top of the strut tower!
