What are the hot dimentions for fit a 10.5 x 28 et street or drag radial
I have an 8" rim now. Also, when going to a 10" rim, is theat when the front lower wheel opening needs to be cut???
Thanks,
RT
Thanks,
RT
15x10 with 6.5 back space and a BFH to the inside area
thats w.o minitub?
a 28x10 et street is smaller than a et drag of the same size. going off memory the et street actually measures 28x9ish.
a 325/50/15 radial will fit on a 15x10 with 6.5.... but youll be hammerin, alot!
a 275/60 radial is closer to the et street 28x10. and would fit without problems
a 275/60 radial is actually 27.6"x9.5 or so tread i think.
For a 28 slick with 10inch rim you will need to a bit hammering on the inside wells.............be patient and careful and it will all work out...do a search on the web for that and there is quite a few write ups
Sorry for the repost...............................
