2003 Chevrolet Trailblazer **Runs Great** $2500 FIRM
sold to the first guy to look at it
Honestly runs great and needs nothing to be a very reliable vehicle. Come check it out and bring a Mechanic or anyone you would like to inspect it.
Clear Green Title
152k Miles
Automatic Transmission with 4wd
Keyless Entry and Remote Start
I have owned since 106k Miles and have performed the following Maintenance.
Rack and Pinion, Inner tie rods and Alignment
Front Lower Ball joints and Outer Tie Rods
Shocks and Struts Front and Rear
Sway Bar End Links Front and Rear
Rear Brake Rotors and Pads
Front Brake Rotors and Pads
OEM AC Delco Platinum Plugs
Replaced differential fluids with Mobil One
Replaced Transfer Case oil with OEM AC Delco Fluid
Coolant Flush
Transmission fluid and filter changed
Replaced Exhaust Manifold due to leak
K&N Air Filter
OEM Fuel Filter
New Battery 2 months ago
General Grabber All Terrain Tires(Awesome in the Snow and have roughly 30k miles of tread left)
I currently drive this SUV 70 miles a day and have had no recent issues other than the battery.
SUV runs great, Drives perfectly on the highway, No abnormal noises or vibrations. Does not pull to the left or right.
I will include all receipts I can locate with sale for any possible warranty issues.
Known Issues
Automatic 4wd DOES NOT WORK(Common electrical issues causes service 4wd light to come on sometimes).
4wd Low and 4wd High WORK PERFECTLY and have been recently used.
Rear Window fluid pump does not work(Front works correctly)
I was also involved in a small fender bender in the winter of 2016. The front bumper and passenger side fender were damaged and replaced(New fender and bumper painted to match).
In 2017 I replaced the hood due to rust around the latch area(New hood painted to match)
If you have any questions please feel to call or text.
Motown Price is $2500 Cash
Thanks for Looking,
Jeremy
734
934-6999
https://i.imgur.com/rR19K8V.jpg
https://i.imgur.com/ql95a7U.jpg
https://i.imgur.com/GvzauX9.jpg
https://i.imgur.com/NLytSV7.jpg
https://i.imgur.com/Hfr99uP.jpg
https://i.imgur.com/18ETWoF.jpg
https://i.imgur.com/C0idNnz.jpg
