Can anyone verify if part number: 04884805AD
is the same as these part numbers?
4884805AF, 68011570AA, 68011570AB, 04884805AF, 68011570AC, 04884805AC
Thank you in advance!
Do you know what makes that design different than these part numbers?
68127987AB
68127987AJ
Could a minor modification or dissection/swapping parts make the later two part numbers into the srt4 pump?
Not sure but Those two are kit part numbers.
AB superseded to AJ in 2017. AJ is still an active part number. Consists of the following components on the BOM:
04884541AJ- shaft balance with oil pump
06512743AA- hex flange head bolts x4
68127985AA- hex flange head locking bolts x4
Hope this Helps
https://www.ebay.com/itm/OEM-NEW-MOP...-/201664281120
That is the oil pump I'm trying to identify if it's compatible with the caliber srt4 or if it's missed marked.
Doing a rebuild and will need to procure a new oil pump for the srt config.
