http://i76.photobucket.com/albums/j7...pso37fnzlf.jpg
Frosted in a barn, it's like daylight.
I have a bunch more frosted ones if anyone late to the party is interested..
I know my dad wants 10-15. I'll let him know you have some, then PM you.
Badass! I just hung 42 in my wife's horsebarn yesterday. Still gotta wire the circuits up. But I did update my barn with 16 and that is like daylight. Debating adding more in there but not sure if it would be too bright.
dumb question - what kind of current do these draw (assumedly, very low)? How many can be put on a 15 amp circuit?
I have two regular old incandescent lights in my garage - not sure what else is on that circuit. I'd like to remove those, and if possible, just use that circuit for these. If needed though, I could run a new 15 or 20 amp circuit specifically for them.
I have a 3 car garage, basically 30' wide and 25' deep. Debating how many I'd want/need in there. I was thinking 3-4 per "bay", for a total of 9-12.
I have 18 in my 2.5 car garage but im blind as a bat, but now i can work all night and no shadows
I have almost the exact same size garage as you. Mine is 9ft walls. I hung 8 originally and now have 14. Much happier with 14. I have 5 per side with 4 down the middle. I went 4ft from each side wall and hung my outside rows. So each outside row hangs on the ceiling from 4ft-8ft off the wall. Then I centered my middle row. I'm 26ft wide and 31 deep. I will go check amp draw right now and post back in a minute.
All 14 of mine pull just over 2 amps total/all together.
They use very little power
Cool, thanks guys. Sounds like I will have 12-15 on the ceiling and I figure 1-2 over my workbench.
How are you wiring them in with the pigtails? Throwing a box on each one? Just drilling a small hole in the drywall to run the pigtail through?
