Originally Posted by
Detroit Gearbox
couple things boomer,
welding the tubes with nickle rod to the center section, adding support bars to the tubes and adding 9" ends are the way to go. Make sure someone uses the proper equipment to check the straightness of the housing. No welding can be done after the ends are on and final straightness of the housing is completed. Use timken set 20 wheel bearings. do not use green brand ball bearings. they suck, and do not hold up well at all.
using studs instead of bolts for the caps is a nice upgrade, and either a TA cover or machined billet cap on the left side will be needed for higher hp applications.
Hope this helps.
