u can if u use the oem gauge cluster
awesome project, theres an italian dude that did this out in cali
cant remember his name off hand but hes all over the internet
what do you do to bypass it, i was under the assumption that you needed the oem cluster to run these with the oem computer
good luck with the project Dan, I'd like to do the same thing to my notch one day
noted thank you, you learn something new everyday ! can you turn the pats off with a normal snap on scan tool or do you have to be a ford tuner""
badass project good luck
dan there is no hopefully about it! that will be BAD ASS when it's done!
