Very cool! I agree, the dark gray would totally set that look off. Look forward to more pics in the future as it progresses.
Looks cool as hell! Tell the kid nice job!
Update!!!
I know its been a while but Im finally moving forward !!! going Gas Monkey garage on it
drove to Norwalk ohio and scored a 04 Towncar front suspension essentially the same as a crown vic only it has cast aluminum lower control arms as opposed to vic's cast iron
also have a new engine and trans combo scored a 1971 400 and a C6 trans 71 & 72 400's were rated at 265 H/P with over 400 ft. lbs of torque
and are 9 to 1 compression
by the time I install a RV cam and a 4 barrel intake it should be over 300 hp and close to 500 ft lbs torque
but I'm undecided on the rear help me choose
I have a 3.73 31 spline posi 8.8 out of a explorer
and a 3.08 open IRS from a Thunderbird
both have disc brakes
cant decide if I want it to handle like a new mustang or be able to out run one
The IRS would be really cool but would need a bit of performance to spice it up. It would probably be a good gear for the build. The explorer axles are a great start too.
