Welcome to Motown Muscle - you in the Detroit area? Or did googling your cars fault lead you here?
I am going in April! There is a Rockabilly and car show called Viva Las Vegas - I went last year and it was fun...
To get back on track - The stabiltrack went on and off intermittently on my 2010 Pick-up with the 5.3. It was the TPS - Once the dealer changed that out, it never happened again. The symptoms were the same - Truck shook, went into the limp home mode. If I turned it off, everything would reset and it wouldn't happen again for a bit...
Just my .02.....grr
So I drove the car a bit today and got all the lights to come on. The only code in the DTC was P0207. "Injector Circuit Malfunction - Cylinder 7" so this is completely screwy. One thing the dealer did last month was all new injectors but I'd be at a loss to see how this is related to everything else. The check engine light was on too in addition to everything else.
A misfire will shut the stabilitrak down so that is probably why they did the tune up, injectors and stuff
