Crazy! Last I knew It was grafted onto a sedan then ripped off that by the next owner...
Lmao! That's right I totally forgot about that...
You seem very talented from following your El Camino and this project. :thumbsup:
The video was very well done and I think you showed both your abilities and your professional demeanor and I hope you get the spot with Power Nation! :cool:
Thankyou! It would be amazing to get a spot, but I'd be geeked to just go for an interview and see the tech center.
Lots of work to be done, but first a selfie
http://i129.photobucket.com/albums/p...pshks0uuaj.jpg
Then on to drip rail delete, I first cut the drip rail into sections, then removed every other section and welded em
http://i129.photobucket.com/albums/p...psodifapde.jpg
This keeps the roof skin from "springing" or warping
Then it was a matter of tack welding and moving to keep a lot of heat from building up and warping the metal..
Once it was all welded, I just hit it with the grinder
http://i129.photobucket.com/albums/p...psp6ojauvw.jpg
http://i129.photobucket.com/albums/p...ps92kupv3v.jpg
Decision has been made and cutting has started, 4" chop it is
Braced up
http://i129.photobucket.com/albums/p...ps2zvzrko7.jpg
Marked out
http://i129.photobucket.com/albums/p...pslxnofl3h.jpg
With the fresh hair cut
http://i129.photobucket.com/albums/p...ps6hw8hxvo.jpg
And the quick mockup
http://i129.photobucket.com/albums/p...psws6jo28n.jpg
http://i129.photobucket.com/albums/p...psxgizhk4x.jpg
http://i129.photobucket.com/albums/p...psnbgea5ur.jpg
http://i129.photobucket.com/albums/p...psoemxblrl.jpg
Roof needs to be quarterd and cuts need to be cleaned up (as they were done with only a saws all...)
But so far so good.
Not too bad looking. Thats about the max id go if it were my own
Agreed
Well
Here she is tacked into place
http://i129.photobucket.com/albums/p...ps16sf6lfs.jpg
http://i129.photobucket.com/albums/p...psvxq2vph2.jpg
http://i129.photobucket.com/albums/p...psybgq7k7d.jpg
Looks good!
