Well I’ve had this car for over 3 years so I should probably do something with it. I bought it turn-key ready to go but things are never the way you want them. It’s a clean rust free car from TN but it had so many issues I’ve only driven it once.
The initial rundown;
Engine:
Dart block
331 cu in. 3.25 stroke 5.4 rod
Canfield Heads
Trick flow intake
70 mm throttle body
Comp Cams .561/.561 248/254
Vortech YSI
Classic FAST EFI
Aeromotive pump, 60 lbs injectors
Drivetrain:
C4, PTC converter
JW bell housing
3.55 gears
Moser 31 spline axles
Detroit true loc
Qa1 tubular k- member, A-arms and coilovers
I hated the loud blower in the garage and dealing with the belt was a pain so I sold the kit.
Picking it up in TN
Attachment 71345
Attachment 71348
Attachment 71347
YSI
Attachment 71349
New plans:
Freshened engine with .40 pistons
TH400 with PTC converter
Holley Dominator fuel system
120 lbs injectors with E85
I can't delete this last picture, wierd.
