Originally Posted by
jameser
I have a Fox Notchback and cannot seem to get better than a 1.69 60'. For info the car has around 600 rwhp and over 700 torque. It has Team Z dual adjustable uppers with spheracle mounts, non adjustable lowers with poly bushings, air bag in pass spring, drag springs front and rear, adjustable shocks and struts, angle is at aprox. -3 tried -2 to -4 still the same, factory rear anti sway bar, front sway bar removed, 27/10.5-15 Hooshier quicktime pro's, 3.55 gear, C4 trans with brake, 3300 converter, Engine is a supercharged 8.2 deck. I am new to the trans brake so have only tried it a couple of times launching at 3200 and still the same 60' as foot braking. I feel this car should pull at least low 1.5 60'. Any help would be great.
