351 Windsor stroker engine for sale
410 cubic inch smallblock. 1974 351W block, ARP main studs, clearanced for stroker, square decked, align bored, Scat 4” stroke cast steel crank, 6.2” h-beam rods, .040” over Diamond forged dish pistons (10.6:1cr), Hastings rings file fit for nitrous, Comp Cams solid roller cam (236/244@.050", .620/.628" lift) and link bar solid roller lifters, Ford Racing Z304 heads, Comp Cams solid roller spring set-up, ARP 12 point head studs, Trend 1 piece pushrods, Ford Racing 1.65 ratio roller rockers (.150” offset intake rockers), double roller timing set, balanced rotating assembly with SFI damper and billet steel flywheel.
Very nice longblock. $7500. I have photos I can text if you PM your number.
Assembled and blueprinted longblock.
I have both early model and Fox body oil pans, water pumps, intakes, etc available so I can complete the assembly and hot test if interested.
