1989 IROC-Z Vortec 4200 Turbo
$14,000 obo. Motivated seller! Located in Dearborn, Michigan 48124
1989 Camaro IROC-Z Convertible. 76k miles on cluster. Odometer no longer hooked up after engine swap. 2006 Vortec 4200 Engine. Custom oil pan. 4L60E with Sonnax kit. Custom Torque Converter 3000rpm foot brake. Moser 12 Bolt Axle, Eaton HD Diff. LS1 Rear disc brakes. Complete Spohn Rear Suspension. 3" Steel Driveshaft 1350. Snow Methanol Stage 2 kit. 70mm Precision Turbo. PT1000 A/W Intercooler. Big Heat Exchanger with puller fan. Remote Mount Meziere Water Pump. Walbro 340 pump, factory fuel lines. Digital fuel pressure gauge. Boost gauge lights up only when in boost and methanol kit is flowing. Champion Aluminum Radiator w/ 17" Puller Fan. Complete rewire with American Auto Wire Fuse Panel and wiring. Cruise control. Bluetooth Radio. Corbeau Seats. Harnesses. Chromoly 8pt rollbar, welded through the floor to subframe connectors. Door bars cut for swingouts. Mojave Heater. Simmons 3pc Wheels. 315/35/17 M/T Drag Radials. Dyna tech 4" muffler + Dynomax VT 3" muffler. This car right now makes 7psi with the full quiet exhaust system. Roughly 400hp. Twist the knob, open up the exhaust, and it makes 500hp at 10psi, 600hp at 15psi.
The Bad. Convertible Top has a few rub holes but functions great. Paint has a few scratches, urethane body parts have some cracks. It's a good base body for a complete vinyl wrap that the new owner can complete.
https://cimg1.ibsrv.net/gimg/www.thi...26ad318209.jpg
