Doing a 5 speed swap on my 93 feature. Car is stock drivetrain. What is a good clutch to go with for not a lot of $$$.
Does Ford Racing offer an upgrade clutch? I know a lot of people used to run the king cobra. If you dont have a power adder then you shouldnt need to worry too much about slippage, more about pedal feel IMO.
yes ford does. $220 for it. Just wondering if there is anything better for less $$
http://www.americanmuscle.com/ford-r...utch-8601.html
that seems like a good deal....
doesnt Valeo make these for Ford? If your looking for just OE replacement, maybe check out Ram, Valeo, and definetly check out Rock Auto....they have a ton of kits for cheap. https://www.rockauto.com/en/catalog/...lutch+kit,1993
$200 isn't bad for a pressure plate and clutch disc. Centerforce is around $400-500
Probably going with just stk replacement now. 3550 trans is going into my blk 92, stock t5 from that going into my 93 yellow which is stock.
Ford Racing, or Ford Motorsport clutch
Oops, yes, the one you posted is a good one.
I went with an Exedy Stage3. Rated for 400 Hp. I think it was under $200 on E-Bay.
