FS: DELL Poweredge T320 server. Xeon E5 2440 v2@1.9GHz. 8 core. (16 total core) 16G RAM.
PICS ----> https://detroit.craigslist.org/mcb/s...993621932.html
This was a clients temporary solution, and was only used for a a couple weeks. Been in a box since. The inside is like new. No issues, noises, or concerns. Everything works as it should. BIOS just upgraded.
The system had Windows 2012 Server Standard installed, and I can reinstall if wanted. Currently has Ubuntu installed. Installed the OS, did updates, and then shut it down. Fresh install.
6 total SATA ports. Perfect home NAS setup or throw some VM Ware on it, and make it the base of your home network. Pfsense, OpenMediaVault, FreeNAS or anything else you want to do with this....Its like new.
Xeon E5 2440 v2 @1.9GHz 8 Core
16G ECC RAM. (4 x 4 sticks, has 6 slots total)
2 Dell Enterprise 7200rpm 500gb SATA HD's
2 Gig network ports
This thing is awesome, and like new.
$250 cash money.
616 four three seven two two nine four (mention MM)
Located in Macomb. Can meet up or deliver, i can bring a UPS so you can fire it up, you bring the monitor/keyboard/mouse.
