Shop that will do an alignment with uncommon things
I'm looking for an alignment shop that will do an alignment without lifting the vehicle, or one that will settle the vehicle on the lift. The suspension needs to be fully settled to ride height in order to get a good alignment due to poor suspension Geometry of a 1970s FWD car (Suspension is from a Toronado). It is torsion bar suspended with lots of tire scrub so there is plenty of binding.
Ideally it'd have 2-4 degrees of caster and around 1 degree of negative camber (factory specification is zero). I'd like about 1/8" toe but factory spec is zero.
I don't have a large flat concrete patch to do it.
Ideas?
http://wrath.com/temp/MotorhomeSideview.jpg
