$1000 or under
$1000 or under
I have an 05 Equinox I'd sell dirt cheap, it needs a head gasket. Has brand new windshield, water pump, radiator, and oil pressure sensor.
2000 Honda Civic EX. 219,000 Miles. 5 speed. Power windows, door locks and sunroof (all work). Runs great but needs an O2 sensor (misfires when switching from open to closed loop but only for a few seconds) has newer exhaust (including down pipe, catalytic converter and cat back system), tires, front brakes, front hub bearings, ball joints and struts. Needs rear brake lines (currently capped at ABS module) and has a cracked windshield, leaks a little bit of oil from the drain plug (oil change place was nice enough to cross thread the plug, I was going to order a new pan since they are easy to change).
Still gets 38 mpg. Needs a good cleaning. Only rust on the vehicle is on the hood.
$800 come drive it away
