it will bolt up or "fit" but your wheels will stick out
How much?
Will that be a big factor when it comes to what rim/tire combo as far as rubbing?
It depends on that wheel & tire combo you are going with. The Mark VII swap Front & rear you cant run 94 and newer rims on the front. If you go with the SN-95 swap you can run pretty much what wheels you want. The axle housings for the Fox...Mark VII (lsc) and SN-95 are the same length. The 3/4 of an Inch Is on the axle Its self. I have an 84 GT vert with SN-95 conversion and I had to roll the rear wheel lip to get clearence. I have stock 84 suspention up front with SN-95 spindles and my wheels fit like a glove. I am running 235-45-17 tires up front & 285-40-17 on the rear with 2000 bullitts.
Any more questions PM me and try to answer them.
crown vic
what about svo? prob rare and not as strong but im pretty sure theyre 5 lug disk outta a fox
