my daughters escape has issues with sensors on her brake system ...
anybody work in a shop that can scan it ?
I would rather pay someone to do it on the side than go to the dealer and get cornholed
When the GM sensors start going off like that you need to replace the Hub. Anyone can do it though, helps to have the install/removal press if it is a similar design.
In the mean time there is an ABS fuse you can pull if it's putting the vehicle in limp mode. Mine did that when I was almost to Florida.
If you take it to Autozone they should be able to scan it and give you a DTC. I can look up the DTC on the Ford repair site for you.
I have a scanner for ABS if you need to use it. Not sure if it will work but we can give it a shot.
