set the car down, it looks like its just hangin there... that spring area should actually be near the rim area. and the tire should be over that part... lower the car some and it will fit better..
i used a real sledge. you can also heat it up with a torch and push it over also...
So if I'm reading this right a 10" rim with 6.5 b.s. will fit? Do you have to roll the lips to do this?
Well its been hammered for sure but no wheel lip rolling. It just might be somthing I need to do in time. 8" rim with a 28 Et street is not getting good enough 60ds.(1.49-1.5x) Plus if we find the missing HP and it make more MPH I not sure I want to go over 140 on a 8" rim. hehe I'm still learning the car but could never leave over 10lbs of boost off the brake. I'll see what happens next year. I still have a lot to learn with the new combo.
Kewl thanks for the help. Maybe I'll try a new set of ET's 1st sence mine are 3years old. DOH
Cool thanks guys, I'll let you know what I find.
