Freeze plug
Freeze plug
Freeze plug and some rtv
Freeze plug would be simple.
If you have the old sensors, using those once modified would work.
JB Weld?
Bottle cap, RTV?
get a couple cup plugs ("FREEZE PLUG") of the required size
That is not the guts of the CVJ, that is a pressed on ABS sensor ring. That is the stem side of the out board joint which has a sealed cup with a stem. The other (boot) side houses the guts, cassette, balls and inner races for the joint.
You can leave it open or cover it, performance will not be impacted either way.
