Working on the car for the past couple weeks. Finished brake lines, moved shifter handle back to center of console, mounted rear bumper and working on front bumper.
Schwartz Performance Inc. chassis didn't have any rear bumper mounts, but had the front ones. I tried buying a rear clip with all of the brackets from them but after 2 months, I got tired of waiting for them to make a set on 'the jig', so I made my own and welded them onto the chassis. Thinking the fronts were OKay, I never even checked them against my original frame, before I sold it.
Anyway, fast forward (?) a year and I am ready to mount the bumpers to the car...The rear bumper fits pretty good even after I had to cut the entire rear clip completely off and remount it because the body didn't fit onto the chassis.
Now I try to mount the front bumper onto the chassis and can't believe it. Doesn't even come close to fitting. The brackets are at least 8" too short, about 1/2" too wide and about 1-1/2" too low. Not one bolt will even line up with the nuts they have welded in the tubing. Rather than flush mount nuts on the inside of the bumper bracket, they drilled a 1" hole and welded around a hex nut. I tried grinding the weld and nut flush with the mount so the bumper bracket would sit flat on the entire mount, but when the weld was nearly flat, the nut fell from the tubing mount.
Since the bumper brackets fit so badly anyway, I just ended up cutting the entire mount from my powdercoated chassis. I am going to make new bumper mounts, weld them to the frame so I can use the factory bumper brackets.
Some pictures of the weeks progress below....There is quite a bit of grinding dust just from cutting the mount from the frame...The mounts are also lying on the floor....
Attachment 81148 Attachment 81149 Attachment 81150 Attachment 81151
