Foxbody drag roller 46k original miles!!! Has never been raced
Selling my 1990 Mustang LX. Car has 46k original miles. I had plans for this to be an 8-second turbo car and started
building the chassis. Car is very solid and rust free. It has never been raced and was stock when I
purchased it. Car has clean title. Have many more pictures just ask.
Asking $8,500
Text or call 734- s3ven six 5 - 7753 (located in Woodhaven)
Notes:. Rear end is installed dry (no fluid). No rear brakes; brake line is capped.
Engine/Trans:
· Stock 302 original engine/mileage
o MSD 6AL
o MSD Coil
o AC Delete pulley
· 3g alternator conversion
· Stock AOD original transmission/mileage (unmodified)
Chassis:
· Diamond Race Cars 10 point chrome moly cage with window net and removable parachute mount
· Stroud single shut with spring launcher
· Diamond Race Cars through the floor sub frame connectors
· Reinforced torque boxes, spot-welded seams with Wolfe Race Craft lower plates. Cage is tied to upper torque boxes for extra reinforcement (cage goes through the back floor).
· 5 point harness mounts
· Coil over conversion (QA1 single adjustable)
· Team Z Anti-roll bar
Interior:
· Car comes without front seats.
· All original interior panels not pictured are included with the car. Car has original black interior. Also, have back seats to go with car.
· New black carpet with padding removed
· Autometer 5 inch tach
· AEM Trans temp gauge
· AEM Oil Pressure Gauge
· B&M ratchet shifter with custom trans brake button.
· Grant Steering wheel (horn still works)
· All factory gauges and lights work
· Heater core and heat is fully functional; AC has been removed
· Radio deleted. Switch panel in place of radio
· Battery relocated to the trunk
· Flaming river push/pull kill switch
Rear end:
· 8.8 rear end housing
· 3.27 Ford Racing gears
· 35 spline Strange axles with 5 lug 5/8 th studs
· Strange Spool
· Racecraft 8.8 Stock style lower control arm housing adjustable bracket kit
· Racecraft 8.8 axle tube brace kit
· 9 inch big axle ends
· 1350 yoke
· Trickflow diff cover with bearing supports
·Team Z upper and lower control arms
·Team Z upper control arm relocation kit
Body:
· No rust anywhere, no bubbles, surface or anything!
· Rear hatch factory spoiler deleted
· Strut towers, frame rails and torque boxes all rust free
· Racecraft strutless wing; color matched to car
· Rear wheel wells enlarged for 29.5 inch tire fitment (looks factory)
http://i489.photobucket.com/albums/r...psxi9r3bgm.jpg
http://i489.photobucket.com/albums/r...psttmeuary.jpg
http://i489.photobucket.com/albums/r...pskqsxy8d0.jpg
http://i489.photobucket.com/albums/r...psep44hcku.jpg
http://i489.photobucket.com/albums/r...psg2odnwyj.jpg
http://i489.photobucket.com/albums/r...pst390jhyb.jpg
http://i489.photobucket.com/albums/r...psyyhbct5c.jpg
http://i489.photobucket.com/albums/r...pstz8suomx.jpg
http://i489.photobucket.com/albums/r...psb6b5lzvn.jpg
http://i489.photobucket.com/albums/r...pse9xh4ohm.jpg
http://i489.photobucket.com/albums/r...psb9pjuvjw.jpg
http://i489.photobucket.com/albums/r...psgmef8uyk.jpg
http://i489.photobucket.com/albums/r...psmyyjbcpc.jpg
http://i489.photobucket.com/albums/r...psnu1fz241.jpg
http://i489.photobucket.com/albums/r...psjhpxcrdg.jpg
http://i489.photobucket.com/albums/r...psm7vcqeno.jpg
http://i489.photobucket.com/albums/r...psqpu27vye.jpg
http://i489.photobucket.com/albums/r...ps2tep0qh2.jpg
