302 SBF Roller block
This is a fully machined block. I got the engine assembled and found the block has some porosity in the casting about an inch or so down from the head deck (water jacket to the outside). The engine was never fired up. I found this while doing cooling system vacuum/pressure tests. Minor leak that I could probably run some block sealer through and get it sealed but I wasn’t comfortable possibly passing on a problem to someone else so I had another block machined and moved the parts from one block to the other. If anyone wants to try their luck with it I’ll give it away free. I have about $700 in this block so it would be a shame to throw it away.
Furnace cleaned
.030” over
Square decked
Cam bearings
Freeze plugs
