3 Attachment(s)
2000 Gmc Safari AWD SLT. $2200 100% Firm
Couldn’t change title: NO TRADES sorry
I am now allowed to sell this, the wife has a hard time letting this go, it’s just sitting in our way.
Been sitting months, and noticed something has a drip, I’m sure it’s simple.
Old pics are gone, she is dirty in and out, is what it is!
This is original add:
Attachment 84813Attachment 84814Attachment 84815
It’s far from perfec, little dings and scratches passenger side Bracket for the ground effects is shot, NOT THE ROCKER.
One of the nicer ones around,
Rear heat was disconnected( unplugged vacuume to valve) due to drip, that line needs replacing if rear heat is a must!
Rear ac works. Door handles are wearing, slack but function as they should, front seats back rest don’t move the handle is warn or stripped I assume possible easy fix just never a issue. Both doors have new window motors.
199k and climbing. Over the last 4 years: all new parts include
Every under hood hose and line, heater and controller valve,trans,cooler,oil cooler all but one steering lines. Starter, alternator,water pump,radiator,distributor, wires, plugs and coil. Intake gasket. Front shocks and rear w/helper spring, tires. Trans: it was gone thru NOT rebuilt but brand new converter, valve body upgrades to delete PWM,separater plates,upgraded vett servos, and accumulaters,pump has new seals etc
Everything recommended by transtar! Seals etc.Drain plug installed in pan. Transfercase has new seals. All gm diff and case fluids recent. No exhaust leaks, pulling or bangs. Makes a noise on occasion usually in reverse on occasion when first put in drive -that is one of the exhaust shields resonating lightly, nothing crazy. A 100% dependable vehicle, we can go for a hell of a test drive so you get a real feel for it loaded with 6-7 people, 4 captains and a bench.
