The tires are a couple years old, I set pressure from 16 down to 13 but usually leave them at 14 psi. I set the pinion angle using an alignment rack with weaver plates and a calibrated digital angle finder from my work.
the tires are a couple years old? that is probably your problem right there. hoosiers are known to wear out fast too.
11-03-2009, 02:09 PM
jameser
Quote:
Originally Posted by Sean
Do you have a video of the car leaving ?
No video.
11-03-2009, 02:11 PM
Sean
Quote:
Originally Posted by jameser
No video.
it'd be hard to help you without video or seeing the car in person. This is a FI car right ? How much boost are you leaving on ?
11-03-2009, 02:12 PM
jameser
Quote:
What tire should I go with? Should I go to a 28" instead of the 27"? I might try and get to the track Sat, whats the temps looking like?
11-03-2009, 02:13 PM
johnquick302
28x10.5 still sidewall mickey thompson slick. i dont know what temps wil be but we will be out there.
jameser
It boost to 12-14 and stays there, depending on belt slip. Yes it is FI.
11-03-2009, 02:14 PM
Sean
how much boost do you make on the transbrake/footbrake at the line and how long does it take for boost to come in all the way ?
11-03-2009, 02:15 PM
orangejuiced86
I'm with John on this one. Try some new tires first.
11-03-2009, 02:17 PM
jameser
Not exactly sure about the boost on trans brake or foot brake but instantly goes to 12-14 when launched.
11-03-2009, 02:19 PM
jameser
