Garage Clean out - bunch of EFI fox stuff and bunch of misc race stuff
***** I have moved to California and am no longer local to downriver. All items include price shipped unless noted otherwise - I have pictures of all Items and can text or email them on request.*****
All parts located in 95655
Call or Text me at Seven three Four, 307, four zero 29. Ask for Derrick.
- $250.00 - (Will trade for 105MM version or LS style 105mm TB) NEW 86-93 Mustang Accufab 90mm TB (black) has throttle cable plate with it. https://accufabracing.com/throttle-b...-throttle-body
- $50.00 - New ACL coated bearings for BBF STD mains. (half the shells are HX/.001")
- $50.00 - Used TB Elbow LS style 102mm to 4500 with clovers.
- $20.00 - Used Ford IAC's from foxbody (Used) have two of these.
- $60.00 - Used Wilson Manifolds 4150 to 90MM fox TB Elbow (installs with TB pointing right or left not front to back)
- $25.00 - NEW Grey TFI module (fox)
- $25.00 - NEW BARO sensor (fox)
- $80.00 - USED Trickflow .080 wall 7/16" push rods (8x) - 9.200" & (8x) - 9.550"
- $60.00 - USED Jacobs ignitions computer ignition and coil - For TFI (comes with plug n play harness)
- $30.00 - USED Pinion snubber for foxbody
- $25.00 - USED 1" aluminum carb spacer 4150
- $25.00 - NEW Torca easy seal 4" S.S. exhaust band style clamps. ( I have 2 of these price is for both)
- $40.00 - NEW NX 4.6 liter billet fuel adapter/fuel block. (for supply nitrous kit with fuel off factory rail or can be used to supply remote fuel pressure gauge)
- $80.00 - NEW TCI Powerglide 300M input shaft for 1.80 gear set (12 5/8" long)Part # 749200
- $25.00 - NEW I have two of these (spares bought for trailer) Jegs SBF 1.6 ratio rocker arms 7/16" stud part number 20134
- $20.00 - NEW LS coil mounts (remote aftermarket style mounts)
- $60.00 - USED Billet aluminum 1/2" foxbody K member spacers with hardware.
- $20.00 - USED Solid trans mount (GM)
- $20.00 - NEW Proform billet anodized 4.030 ring compressor/piston installer.
- $30.00 - NEW Billet aluminum 100mm throttle Body. Comes with weld on mounting plate if fabricating intake.
- $220.00 - USED MSD probillet TFI distributor part # 8456
- $80.00 - NEW MSD window switch part# 8950
- SOLD
- $40.00 - USED MSD window switch part# 8956
- $25.00 - USED ABB Digiset with base.
- $40.00 - NEW Summit roll stop kit Part #SUM-760000
- $20.00 - USED Summit roll stop SOLENOID ONLY part # SUM-760000
- $140.00 - USED Aeromotive SS Billet Series 140gpm fuel pump Part# 11213
- $30.00 - NEW fiberglass header wrap 2" wide
- $80.00 - NEW BBF front motor plate 1/4" aluminum
- SOLD
- $200.00 - USED Factory 1989 Engine control harness, in good shape Foxbody ECM harness
- $500.00 - BUYER PAYS SHIPPING - Edelbrock Super victor for 351W, drilled for two foggers; comes with ONE NOS pro shot systems (no bottle)
