Is there a way to get RPO codes from the VIN? I bought an 87 GTA and would like to do a partial restoration. It has some rare options and is a unique color.
Here is the VIN
1G2FW2186HN232338
Here is the VIN
1G2FW2186HN232338
The trim tag on the cowl panel will list the RPO codes later they were moved to the door jambs and underside of the trunk lid.
I think it is too old for VIS or it's got a typo. Sorry.
Thanks for the effort.
The VIN is correct, i copied and pasted it and ran it through vincheck. There is a high probability this car is a 1 of 1. I was hoping I could authenticate it.
I checked the glove box door
the rear cargo area glove box lid
the doors
front seats are gone
original carpet is gone
Any other ideas? My assumption is the RPO label was on the glove box lid. I could not locate a build sheet anywhere either, but the interior is missing many stock pieces.
Check the top of the gas tank for a sheet? I think I found one under my rear seat but if that's gone that's the only other place I can think of to look.
I think on my g-body it's on the underside of the trunk lid.
Have any photos or any other paperwork for the car?
Is it possible to identify the original selling dealership?
RPO sticker on those is usually on the underside of the center console lid.... sounds like its missing
if it was a ford I could prob. look them up with the vin.... someone else may have GM access
I didn't run the codes, but from my research it is not 1 of 1
From what I can see it is...
68U -- Exterior Color, Dark Russet Metallic -- 372
It is equipped with...
U52 -- Instrument Cluster, Electronic -- 5,352
PW7 -- Wheels, 16" Aluminum Diamond-Spoke -- 17,240
QDZ -- Tires, 245/50-VR16 Radial -- 20,607
L98 -- Engine, 5.7L V8 TPI -- 7,818
MXO -- Transmission, Automaic Overdrive -- 27,007
AU3 -- Door Locks, Power -- 23,704
A31 -- Windows, Power -- 28,813
Interior is one of these.
How can I tell which one? What is the difference between Camel and Carmine? Rear seat is present and appears to be corduroy? Door panels have leather. Seats have power hookup and lines for vac lumbar? Has overhead console and auto dimming rear view as well.
62B -- Trim Combination, Camel Cloth -- 185
62C -- Trim Combination, Camel Cloth -- 1,105
62D -- Trim Combination, Camel Cloth -- 3,995
62E -- Trim Combination, Camel Cloth/Leather -- 65
