Welding holes up on support...and will move to engine bay this week. Attachment 81772
will post a pic when I get the support all welded up...BTW...using a Lincoln 180 mig. lol
Attachment 81791Attachment 81792
a little more work this past weekend. spot welding panels in. will seam seal everything along with fill and block to baby butt smooth...
more welding and grinding....first coat of filler Attachment 81864Attachment 81865Attachment 81866Attachment 81867
More Attachment 81903
:specool:
--Joe
PRIMED engine bay....coming along Attachment 82074
after poly primed...sanded everything for high and low spots...did some more body work and then primed with K2 primer....let dry for a week and started water sanding with block and 400 grit. Will check for imperfections and fix and then prime again next week. I think the next priming "should be the last" before i seal and start laying colorAttachment 82151Attachment 82152Attachment 82153Attachment 82154Attachment 82155
Awesome, following!
Attachment 82213Attachment 82214Attachment 82215Attachment 82217
sealed engine bay....since I am using spies...I have a little more time to hit is with clear. I will try to spray the clear next week. So far so good though....
