Half my electrical in my house is not working.
It just stopped working tonight.
I need to get someone out here.
Anyone recommend a electrician?
I’m not a electrician BUT I did stay at a holiday inn express last night.
One of the two Big main fuse’s outside in small panel before meter?
A/c may run into it also.
This must be it. I wouldn't know how to check or test it?
Attachment 82459
Use a continuity tester across the fuse. If it beeps the fuse is good, if not then it's blown.
--Joe
Please don't laugh......what setting do I use on this to check it?
I can check it with this correct?
Attachment 82461
Setting looks good where it's at. Turn it on look at the screen then touch the 2 leads together. You should see it change. Then when you go across the fuse it should behave the same as you touching the 2 leads together.
BE CAREFUL.... There is power in the box. BIG power
Even if you pull the disconnect that's just the power going to the house. The power from the lines into the box is still hot.
Get it figured out yet, if not you got a apple to FaceTime I can help walk you through
This is bad, I also don't have water, well pump is one of the lines out.
At least the furnace is working & I could plug the refrigerators in other
working outlets.
