am I wasting my time?
or could I get a better deal from painters supply?
I want to paint my f 100 flat black and dont have alot of money
and would a gallon be enough for a full size pickup?
Post links of what products you're looking at. And a gallon will not get the job done.
John deer blitz black cheap and works perfect under 100.00 will get you done
I have a few spray guns you can borrow if it helps im in dearborn heights
I have two gallons of sikkens viper black, with activator that I will sell cheap. It's been sitting around but it's still good.
hot rod flats- flat black cheap and new and available everywhere
Need at least 5 quarts to do a standard cab long box, if you do inside the bed and inside the wheelwells.
the chepest place for paint i seen is on 13 on grosebeck there paint is thicker the painters supply and matchs really good and its 5-10 bux cheaper a pint i personally dnt like painters supply
and a gal should be enough...it will reduce out to 2 gal's unless flat paint is diff and not 1 to 1
I remember seeing this article a while back. They used rustoleum flat black and painted the whole car for $130.
http://www.hotrod.com/techarticles/b...flat_painting/
If I ever had a grudge car I would be going this route.
Whenever you get a supply of paint making sure that:
It gives good quality and standard
Color is according to requirement
supply is in time
