Originally Posted by
wikdsvt
How do i do that when the Axle sits on top of the leaf spring? I can't bolt it to the leaf spring without the perch, I can't put the perch on until i know the pinion angle?
How can i support the weight of the car with a load on the springs without the axle attached? Put 2 jack stands under the leaf springs and just set the axle on the springs without tires?
jack up car, remove rear leaf spring from one side, put axle in, reattach leaf spring, lower car so weight of leaf springs is on the jack stands, position and measure axle for perches? I sure hte hell don't want to climb under a car being held up by jack stands under the leaf springs...
Thoughts?
