I have a 91 convertible mustang, and the door shake as if their not completely closed when I hit bumps. I have had the striker tightend, but they still loosen back up. Can anybody help me??
is the weatherstripping good?
Is the frame tied?
Did you check to see if the hinges were wore out? Lift the doors up/down. If theres play replace the pins/bushings.
Thanx guys! Everything that you all have suggested I have not tried yet and makes a lot of sense. I have a set of full frame connectors that have not been installed yet, the weather stripping is old and the doors do move up and down when I lift on them. The frame connectors were my first thought along with a roll cage to stop some of the uni frame movement. Thanks again!
