I’m curious what you need jumper bars for? If your doing it with no power on, remove the meter, do it then reinstall the meter.
Just going off of my past experience
You already have a modern zigbee meter, no? You're not going polyphase, correct? If so, they don't care. There will be an exception thrown that the meter was interrupted for power. If it's off for a whole day someone might look into it. But I doubt it, because if it's out for a few days if it's important the customer will call. Otherwise it's a meter issue and eventually they'll roll a truck and swap the meter.
Modern meters (what you have) are really difficult to tamper with. You can do it through the optical port or over the air, but it will still flag that someone's been messing with it. The tamper tag is largely ignored. All it does is remind the technician to pay attention for shenanigans.
How long ago was it you used the jumpers? Pretty much no one uses them anymore for risk of arc flash.
By now if you didn't have a smart meter they'd be charging you for it because you opted out... or you're somewhere super rural.
I wouldn’t recommend trying any of those ideas in Consumers territory. They can and have successfully prosecuted people for theft of energy by removing the meter carrying a $5,000 fine. The meters there generate their own work orders after 15 minutes of loss of power.
