The p0300 fun code 2000 Yukon 5.3
Starts a little rough, quick stumble and then idle first try when cold and gets worse when warm ,meaning up to three attempts of stumble and stall or extended stumble and finally raise to idle WITH noticeable miss at idle at any temp. No off idle/drivability issues, smooth throttle response.
Plugs and wires are new
Fuel filter= OK
Fuel pressure @50 spec calls for 55-60 ish
carb cleaner vacuume leak check= NO Leak found
I just got a hf special centech scan tool 60794 w/lsd and playback, but I have never used any scanner so the info might be there but I don’t know what the values should look like anyway.
Just give me the fix and problem solved is the ideal situation But.....
Seriously if you have ANY helpful pointers or suggestions where specific info can be found I would appreciate any positive direction.
