R302 based 359" Shortblock Built for Boost
Selling an R302 based 359" shortblock. All parts are 100% new and unused with the exception of the block (was used when it was smaller 4.030" bore) and the oil pan.
-FRPP R302 Block
-3.400" stroke
-5.400" rod
-4.100" bore
-Set up for High Ports
-Other inline heads may work (this is on the buyer to verify)
-Forged Eagle crank
-Forged Eagle h-beam rods with ARP 2000 bolt upgrade
-Custom Bennett Spec Ross Pistons with small dome (2.95cc)
-Thick wall tool steel pins
-Internal balanced
-AP Tool Steel rings gapped for big boost
-Clevite HP bearings throughout ; rod bearings hand radiused on fillet side
-ARP studs throughout
-Precision blueprinted oil pump ; standard volume, high pressure spring and shimmed
-Canton windage tray
-Canton pickup
-Canton 7 quart oil pan ; tapped for oil return
Does not come with:
-Harmonic damper
-Timing chain set
-Cam
-Oil pump driveshaft
-Anything else not listed above
With a 68cc chamber and 0.052" gasket, static compression ratio is 10.25:1
Rotator is properly clearanced/assembled, but oil pump/windage tray/pickup/pan are not installed.
Would cost roughly $8,000 to duplicate this setup as it sits - if you can even find an R302 block to begin with.
$4000 picked up. Located in Port Huron, Michigan. Serious buyers can come look in person.
No trades and no pic collectors.
810-990-9842 is my cell since I don't check here often.
