New Build 306 SBF
SOLD
Fresh build. It was built for an early Mustang and hot tested then decided to switch it to a Foxbody setup.
Roller block
.030" over DSS forged flat tops
'68 rods with ARP bolts
Clevite 77 bearings
Balanced rotating assembly with Flywheel
High volume mechanical fuel pump
SVO GT40X heads
F303 cam
Double roller timing set
Trick Flow 1 piece pushrods
SVO 1.6 roller rockers
Edelbrock Performer RPM intake
Ford Motorsport valve covers
MSD distributor
March underdrive pulleys
March alternator bracket
1 wire alternator
Equal length shorty headers
Fox body oil pan
Stewart standard rotation water pump
SOLD
I have water pump and pulleys to convert it to a reverse rotation setup. I also have an early pan for 65-73 setups.
I could also delete some of the peripheral parts to drop the cost some.
