Resonator Delete H-Pipe for 2015+ 5.0L GT Mustangs
This H-Pipe has been on my car for about a year and has not seen snow or salt. I swapped over to a full Corsa setup and no longer need this pipe. This is a great mod to give your exhaust a louder more aggressive sound. NO TRADES AND CASH ONLY! ASKING $200.
This Resonator Delete H-Pipe easily replaces that bulky and restrictive OE Resonator. Manufactured completely out of CNC mandrel bent 304 Stainless Steel tubing, this H-Pipe will bolt-in place once two simple cuts have been made and the OEM segment is then unbolted and removed. The new H-Pipe will reuse the two factory clamps found on the front and in the rear section after the applicable cuts have been made will connect with supplied clamps.
Features and Benefits:
- Replaces Factory Resonator with a More Efficient H-Pipe
- Significant Weight Savings Over the OEM Resonator
- Aggressive Exhaust Note Even With OE Mufflers
- Simple Cut-And-Clamp Bolt-In Installation
- Full 304 Stainless Steel Construction with Precision Welds
- CNC Mandrel Bent Tubing Ensures a Smooth Exhaust Path and Precise Fit
- Includes All Necessary Hardware and Clamps
*This Resonator Delete H-Pipe does NOT require any welding.
*Tuning changes are NOT required for a proper installation.
http://i76.photobucket.com/albums/j4...psum9ejtjb.jpg
http://i76.photobucket.com/albums/j4...pstyumt3uo.jpg
http://i76.photobucket.com/albums/j4...pssmisgtir.jpg
http://i76.photobucket.com/albums/j4...psrubksnao.jpg
http://i76.photobucket.com/albums/j4...psplaut7ms.jpg
