Just want to know what kind of rear upper and lower control arms you guys are using on your fox bodied stangs, and what kind you recommend for street-strip use
Team Z. Great products + club sponsor.
Wolfe team z are a couple I have uppers and lowers for sale check the sale section
looks like your new here. details on your car would help too.
Yeah I have been here since 07 but read alot of post and answer most of my own questions there but my car is notchback with a 359na efi windsor and t5 with a 8.8 im running drag radials at 265-60r15 but even after a good burnout and only 14-15psi in the tires i either get wheel hop or spin most of the time i also have a set of eibach sportline springs i wasnt sure if i could get a ok ride out of dragsprings on the little bit of street time it does see so thats the reason i went with the sportlines i got the rearend pulled right now for a gear swap and i plan on welding in battle boxes so why not add some control arms
Sounds fun!
i think i ran my DRs as low as 11psi and it only ran 12.60's.
ok yea Im living in tennessee now and they only run 1/8th mile down here so gears are a must no more 3.08's
I run Team Z relocated double adj. uppers and single adj. lowers.
