9 second, everything works, drive anywhere 2010 Camaro SS Twin Turbo!
2010 Camaro 2SS/RS automatic with 46k miles.
Car has every option except factory stripes. Has Sunroof.
Car has the 2012 factory HUD system and rearview mirror backup camera installed
Car was driven to and from track on an 80 degree day and ran 9.97. It has been trailered on a cooler day and ran even quicker! (will share quickest pass with serious buyer) No meth, nitrous, or race gas needs to be added to make the car run this fast. Just use pump grade e85 fuel. Vehicle is set up with flex fuel to run e85 or premium fuel
ENGINE:
Texas Speed stage 1 camshaft
BTR .660 springs
BTR pushrods
DOD delete
VVT delete
VMAX ported throttle body
Catch can
LS9 headgaskets
Lingenfelter 174 thermostat
Lingenfelter 2step
ZR1 MAP sensor
Forced Induction:
Huron Speed twin turbo kit
Comp oil-less 60/65 turbos
Turbosmart Hypergate 45 wastegates
X/S BOV
4 inch black intercooler
Turbosmart manual boost controller
Fuel System:
Livernois Firestorm dual fuel pump with original pumps removed and DW 320 pumps installed internally
JMS Boost a pump
SMG Aux pump
AUS 115 lb fuel injectors
GM Flex fuel sensor and tune
Transmission:
GM reman installed in 2018 and refreshed in 2020 with Sonnax 456 apply piston
Vigilante 3200 multi disc stall converter
B&M trans cooler
Suspension and Chassis:
Lightweight front tubular crash bar
Baer lightweight 2 piece front rotors
Hotchkis rear subframe brace
Hotchkis rear swaybar
Pfadt rear trailing arms
BMR rear toe rods
Rear cross drilled rotors
MISC:
2014+ SS hood vent
2013 1LE rear spoiler
Red brake calipers like 1LE
2 sets wheels and tires:
Stock 20’s painted black
17in Racestars with Mickey Thompsons
ZL1 aluminum gas/brake pedals
Z28 battery (lighter than SS battery)
Everything works on the car including the factory remote start. It has 46k miles and garage kept. It put down 882 rwhp 15-16 PSI. Tuned by Power Dynamics (previously Dr Phil)
New low price $28k – Exceptional deal for a 9 second car with all working features that can be driven anywhere and no need to add meth or nitrous! NO LOW Offers! I doubt you will find a car with everything working and verified in the 9s for this price!
Clean clear title in hand. I am 2nd owner and have original window sticker
More photos, details, and videos can be sent upon request
NO TRADES
Pictures available here:
https://detroit.craigslist.org/mcb/c...299449366.html
