1999 Explorer Limited 5.0 AWD
Selling my trusty DD Explorer. I intended on keeping it until something catastrophic failed or it was totalled but its time for an actual truck now.
The truck is 100% mechanically sound and will take you anywhere you need to go. It does great in the snow with the full-time AWD. The engine and transmission run like they're new, no joke. Ive done a good amount of preventative maintenance over the past couple years, myself, as well as some small repairs at Oval Auto when necessary. I have receipts for pretty much everything. Oil changes done regularly with Mobil 1 synthetic and Motorcraft oil filter or Mobil 1 when they're on sale.
I bought it in 2013 with 136k miles from my friends parents. They had it shipped from California to Michigan in 2004. It has been undercoated so the frame is in pretty good shape for it's age. The body is starting to rust in the usual spots like rear door jams, roof, and rear bumper. It has dings and scratches and definitely isn't perfect cosmetically.
Only bad things are a cracked windshield on the passenger side, drivers side heated seat stopped working a couple years ago and the rear wiper randomly stops working every so often.
$2000
211k miles
Avital remote start and keyless entry
HID retrofitted headlights with Morimoto Mini H1 projectors and XB35 bulbs
Pioneer double din head unit
Alpine Type-S component speakers in front and coaxials in rear
Clarion sub in factory sub location
20% tint on the front windows
Pre-wired for aftermarket amp and sub. I will include the amp and sub if youd like them for an extra $200
Following was done within the past couple years:
Trans fluid and filter change with Mercon V (not flushed)
Transfer case fluid changed
Moog balljoints, upper control arms, tie rods, sway bar endlinks, front hubs
Rancho front shocks
Moog u-joints in rear driveshaft
Monroe coilover rear shocks and 5th shock
Warrior 153 lift shackles
Procomp add-a-leafs
Torsion twist up front
32" Cooper Discoverer ATP tires
New OEM trans cooler hard lines (all 3)
New passenger exhaust manifold
New fuel pump assembly (done last week)
New fuel filler tube and hose
New battery
New alternator (last month)
New air filter
New Autolite spark plugs and Motorcraft wires
Coolant flush and fill, thermostat, and new radiator hoses
New brakes front and rear (ceramic pads and rotors)
New Walker oem replacement muffler and tailpipe
New upstream o2 sensors
https://live.staticflickr.com/65535/...57df2329_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...bc58cec3_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...a1ce03cf_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...b8ede2e1_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...3fabfd7f_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...99909089_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...5cccf933_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...3f6b7457_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...f0f0a79d_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...6e78a6f0_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...6a2d3dc5_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...a0f84d14_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...1e21b14b_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...9c1414d3_b.jpgUntitled by michiganz, on Flickr
https://live.staticflickr.com/65535/...4ce864e4_b.jpgUntitled by michiganz, on Flickr
