2000 gmc safari bucking at part throttle
about a month ago wife had a issue in wet/slushy condition van started misfiring and staled but after a few minutes started,when I got home pulled the dog house noticed the coil wire half off and figured she had 80k on it since we got it and did a new coil,wires,plugs,cap,rotor also fuel filter. No issues till sat night it did the same thing except it backfired when she tried restarting it. It now has a bucking(I don't think ignition break up) it is a erky jerky/ smooth-rough-smooth-rough etc.. when normal driving off idle and a slight bucking at speed. If I dog on it no bucking. fuel pressure guage shows good even when it dose it, haven't found a vacuum leak nor a ignition arching issue. no cel
so many possibilities I started pulling maf plug( it ran better but not 100%) no cel. With maf pluged in pulled tps,crank position sensor and iac and nothing happened at all no cel no change in bucking.
scanner is showing 99.2 stft b2, tps .004 or.04 at idle and barely jumping to .0/.007 for a sec when playing with throttle then settles back to the 4.
I can not interpret what the scanner is telling me, and without a good one and ability to understand it mine will do me more harm than good I think.
With almost 200k should I start with possible dizzy gear being worn, ecm,maf,iac,ETC..r2d2,pms lol.
I really cant just throw money at it in hopes
If you are able to scan and near me I can drive to you and compensate.
If you know any thing im ears.
