:wavey:
Oh yeah totally forgot about that! $50 for all of that. I'm excited to explore into the world of paint correction! Kinda intimidated to be honest but i'm sure i'll make it through haha Thanks for the advice/input. So on something like minor swirls what process of correction should I be taking? Wash/clay/ssr2.5/ssr1/exp polish then the nxt?
i would like to use the product once a month or every other month. its a daily driver so id prefer more durable than not, live in the city so water is pretty soft. car is not garage kept, id like a little of both brightness and the liquid look. id say mainly the pearlescent brightness. thanks Marc!
Im wondering what type of wax is ideal for a black car. The paint is already in very good condition (IMO). I have been using Meguiars Gold Class paste wax with decent results, but am looking to step up to better products. Any suggestion?
Thanks,
Ryan
I tried the 1ZCP yesterday to wipe down the interior, and WOW! that stuff is the shit. Definitely a fan now.
Hmmm... I see.
Well here's the thing: with not being garage kept, the protection will diminish much more quickly - even on a white vehicle. White doesn't absorb nearly as much heat as black (black paint can hit over 170 degrees in the summer even in Michigan), but the UV rays of the sun will certainly affect how a product performs.
Because you have beautiful pearl paint, to show it off as much as possible you'll want a product with a lot of clarity so it really "pops" in the sun. I'd recommend you stick with an easy to use, highly durable, and very slick sealant for now: something like Blackfire Wet Diamond, Menzerna Powerlock, Chemical Guys JetSeal109, or Wolfgang Deep Gloss Paint Sealant 3.0. The durability of any of these should be at least a few months in your conditions, and the slickness will help to keep things from sticking to your car while making it a lot easier to wash. If you'd like to add on a coat of a high quality wax, I'd recommend you look into a product like Dodo Juice's White Diamond. White Diamond's formula is based off the early Supernatural formula and has outstanding clarity for a carnauba wax. You could get another quality but less expensive wax, but many carnauba waxes are known to dim down metallic flake / pearl in paint. White Diamond will give you a nearly identical look to Supernatural at a fraction of the price, and both will have similar durability (maybe around 2 months for your use).
I hope this helps!
Ryan,
Meguiar's Gold Class has a big following for a reason: it's known to be a very nice wax, especially for the price. I think the only other Meguiar's wax that can compete with the following of Gold Class is Meguiar's #16 Mirror Glaze which isn't sold in the US any longer and seems to have a cult-like following.
To answer your question though; first take into account that the prep work is the most important aspect for ALL cars, but this is especially true for black. Black shows everything - so the easiest way to think of your paint is like a mirror. A mirror that is dirty and hazy will still reflect, but not nearly as precise as a super clean highly polished mirror. Swirls, scratches, marring, etc all take away from the clarity of your paint, and in no other color is this more obvious than on black. Get your "black mirror" looking perfect and it won't matter if you use waxes like Zymol Royale, Swissvax Divine, or Turtle Wax. It's all about the prep.
Will its easy to talk about polishing your car correctly to a near perfect finish... in reality that's a very time consuming process and requires a lot of specialized products and know-how. Here's a low budget short cut:
Glazes & All In Ones.
A glaze is a product typically used for show car prep that adds either oils or polymers to give a wetter look while temporarily filling in light swirl marks. While they usually only last for a period of 2-6 weeks, for that time you'll see a visual reduction in swirls which equates to a darker finish that gives your a more reflective look from the increased clarity.
All in One products (AIO) can be thought of as a "Jack of all trades, master of none." They have some light polishing agents in them which will help to resurface your finish very slowly. Those abrasives will round-off the edges of swirls and scratches as the product is worked into the paint. Rounded edges don't refract light in the same manner, so you'll notice that after a few uses, you're finish has actually improved resulting in a more reflective finish from the increased clarity. In addition to the polishing nature of AIOs, they also leave behind a little protection which will likely last you between one and two months.
I hope this gives you a better idea on how to get that much more out of your black car's paint. I could recommend some other actual wax products, but I think you'll likely see a bigger difference in a Glaze or AIO product over a luxury carnauba wax.
What took you so long!!! :P
Told you that you'd love it. We're still on our 10L jug (only about 1/4 left!), and have had a lot of clients turned into believers.
Thanks for the help Marc! +1
