Originally Posted by
smooth
Are you planing on spraying completes? Because my concern with spraying a complete with a 30gl compressor is moisture in the lines, I used my Sata's with a 25gl craftsmen and most of those guns require 10-15 cfm's @ 40 psi which translate to nearly 6-10 cfm's @ 29psi which most painter's spray at. To be honest even if your a novice,expert,or whatever I prefer someone buy a quality gun they can rebuild in 5 years if they need to and finding parts for a random manufactured gun may be hard. Go with a reputable gun manufacturer, DeVilbiss, Iwata,Sata, if your looking for inexpensive definately look at DeVilbiss they make some nice equipment for cheap
