First thing I'd do is clean the door jambs!
I'm also wondering what you'll do with that. Enter competitions?
It will be my daily 160+DB.
Maybe enter comps with it also.
Don't mind the surface rust/mess on the rotors. Had to swap out the SN95 axles to Foxbody length because they were rubbing my quarters when it bottomed out. Of course,dumb me miscalculated so a simple axle swap turned into a project. Did the Foxbody/SN95 backing plate mod/flip. Everything seems good so far. https://uploads.tapatalk-cdn.com/202...a0fc8a066b.jpg
About to rebuild one of my TR3650s. https://uploads.tapatalk-cdn.com/202...6b5912f5f1.jpg
Happy New Year!
I spent New Years Eve in the garage making some updates to the Mustang. I did an AJE Colt65 suspension swap, its comprised of Fox/SN95 Mustang suspension.
Quick info on the update, Maximum Motorsports Fox coilover struts, custom built for additional bump travel, MM Caster Camber and Bump Steer kits, SN95 13" Cobra brakes (upgrading from the S197s I previously had installed)
Swapped the 4-Speed toploader with a T5
freshened up the 331 stroker, found a couple leaking valves so I relapped them. Replaced the front sump pan with a Fox style rear sump.
Here are some pics Dont mind the wheel spacers, they were just there for mock-upAttachment 87198Attachment 87199Attachment 87200
Getting closer to finishing my electric steering upgrade https://uploads.tapatalk-cdn.com/202...3d70f29c5e.jpghttps://uploads.tapatalk-cdn.com/202...8d3619e283.jpg
Sent from my Pixel 6 using Tapatalk
Current nightmare...
Attachment 87280Attachment 87281
^^^ Love those cars!!!
Had several, two of mine....
https://i.imgur.com/WIYy1Qn.jpg
https://i.imgur.com/U0JGs5B.jpg
Finally got my garage organized and put away this weekend. Now if I can just find time to work on the car.
https://i.imgur.com/hV4FreV.jpg
