I would talk to these guys
https://www.injectedengineering.com/
Thanks everyone for your input. I will definitely call these guys and see if they can do a remote in. Since I have the software, it will only cost me about 50-100 for enough credits to take over the tune to my own hardware. Then what ever there charge would be. worst case, its only 7 hours to drive there.
It says boost controller, do you have a gauge, or anything that shows if it is making boost/pressure in the intake?
Seeing what Geoff stated above, I'd think/hope that they hold it in gear and make the pull, but if it doesn't make any boost until 100mph, it's all pretty useless unless you're running a Supra on the highway from a roll...
No Gauge that I can see. I looked up that controller on the website and it shows a digital readout. So I am going to fine tooth comb my vehicle tonight. And honestly, the build was supposed to make power below 100Mph. That was my goal going into it and this was the system they recommended. I didn't want a S/C as it didn't scale as well for my future plans.
--Double posted
Detatch the boost pipes and run it. Should still run 14.2 with no boost. If it doesn't, you got screwed.
I am not familiar enough to know what may fuck something up. Do you mean just disconnect near the intake and just let it push air into the hood area? Or somewhere else?
Well I have boosted stock engine with a tuned PCM. When I twist my boost knob, my wastegate gets restricted and I get more boost. When I get more boost, my tune adds fuel and pulls timing. I can run 7psi, 8, 9, 10, 11, 12, 13, 14, 15psi because I only have a 1 bar map sensor. These are set curves. I imagine if I unhook my intake piping, my car would run just like stock, around 280hp...
Well not really because you don't want the turbos to spin without resistance on the compressor side. I would unhook the exhaust before the turbos so they don't spin and then unhook the charge pipe to the throttle body. The engine alone has to run properly before any boost is added.
