I know that the SN95 shafts are 3/4'' longer then the Fox but does any body know about the Housing? are they the same width ?
I'm 99.999999% 79-98 8.8" axle housings are the same width. 99-04 are the years the housings are wider. They are the same part numbers from Ford Racing (79-98).
The only way around, is through
Yes the housings are the same.
'86-'98 8.8" housings are the same. '99-'04 8.8" housings are wider and they have larger bolt holes for the LCA's.
--Vince
hey vince
this is sky
my question is
How or why do you need to relocate the disc brake bracket on a early sn95 housing for the fox length axles?
"BUILT not BOUGHT"
95 F250 4x4 12"s of lift on 38s
Cummins swap someday
To attempt the destruction of our passions is the height of folly. What a noble aim is that of the zealot who tortures himself like a madman in order to desire nothing, love nothing, feel nothing, and who, if he succeeded, would end up a complete monster!
Denis Diderot
To run the SN95 rear brakes (Cobra or V6/GT) on a Fox you either need '94-'98 axles and stock brackets, Fox length axles and North Race Cars brackets, or Fox length axles and modified stock brackets.
Any of the three options will work. My choice is modified brackets and Fox length axles. SN95 axles will limit your maximum wheel width to 8" and NRC brackets cost $150.
Let me know if you have any more questions. I did a detailed write-up on the bracket modification on FEP and I think it was also copied onto the Corral.
--Vince
im on 4ep as well are you talking about this modified brackets??
http://vb.foureyedpride.com/showthread.php?t=71585
"BUILT not BOUGHT"
Denis Diderot
What about turbo coupe and explorer lengths?
