Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: MIG Wire for Sheetmetal
    Club Member monster.'s Avatar
    Mar 2005
    detroit zoo
    1,590
    Default MIG Wire for Sheetmetal
    I'm using .025, with pretty darn good penetration. I'm at a very slow wire feed, with a high heat seating.
    What i'm having trouble with is the puddle (I don't get a nice puddle 20% of the time), I'll blow thru if I keep on it too long, but if i'm too brief with the arc, I don't get good penetration.
    I've done everything so far (I think)
    75/25 Ar/CO2
    .025 MIG (i'll get the spec later)
    tried several different grounds, even a magnet
    prep the steel.
    Should I go to a large diamete wire?
    Help
    The only way around, is through
    Club Sponsor jdustu's Avatar
    Sep 2004
    Mt. Clemens
    7,411
    .025 should work, you've just got to play with the settings to get the machine set right.
    It's my fault for making it look so easy.
    Mar 2005
    detroit zoo
    1,590
    I think my rollers and sleeve go up to .040, i'm going to buy a spool of that and see if I can get more consistent.
    Thank you though
    Sep 2004
    Mt. Clemens
    7,411
    Quote Originally Posted by monster. View Post
    Thank you though
    That is waaaay too thick for sheetmetal! .025 should work.
    You need to play with your heat and wire speed and travel speed. Try turning down the heat/turning up the wire speed. Maybe try moving slower.
    Make sure your keeping a consistent distance arc length.
    Mar 2005
    detroit zoo
    1,590
    Quote Originally Posted by jdustu View Post
    DING DING DING - I bet that is it
    good point, now that i think about it, i'm all over the place regarding arc length - eh der! I've laid great welds with good penetration, and then i'll get a burn thru. I'm like WTF over here, move the ground, adjust amps/volts.. i'm like is it wire. I'm really all over the place.
    Thank you
    You know whats helped a ton, is using copper as a heat sink. I'm butt welding the panels in, and the copper made a night and day difference.
    cool man thanks
    Sep 2004
    Mt. Clemens
    7,411
    Thank you
    cool man thanks
    Right on!
    I don't mig sheet metal much, but I use copper as a backing plate a lot for other stuff.
    Consistency really is the key. It's hard to adjust a machine if your arc length and travel speed is all over. Get those consistent, then you can mess with the machine a little bit at a time and really see the adjustments work....and after that you can even work backwards and mess with your travel speed.
    The hardest part of mig welding is getting the settings right!
    Club Member SVT32VDOHC's Avatar
    Jun 2007
    Metro Detroit
    8,692
    I don't know all the numbers and settings for welding, but like Josh said...play with the settings and you will find what works best. If I am blowing the pool out I personally will let off for a second, wait for the red to cool down a hair, then zap the trigger again. It usualy fills in very well.
    Club Member slideways's Avatar
    Dec 2004
    In the paint boof
    14,256
    Most sheet metal welding i do is done with tacking or very short welds. The .025 should work great for you. Just be careful to be sure not to put to much heat into the metal (if you doing body panels) or you will create a big mess for yourself.
    '00 Stage 2 Roush Mustang 2v Swap...
    '04 YFZ450- Turbo Stock Bore
    '04 Sierra 2500- CCSB LB7
    '01 Blazer- 5.3 Project/Garage decor
    Twister Racing 2k13
    Mar 2005
    detroit zoo
    1,590
    I'll try to get some welding done this weekend. The other thing I need to try is grinding both sides of the sheetmetal a little bit more. I just don't want to grind away too much, the sheetmetal is thin enough.
    I'm pretty good keeping the panel cool, I use compressed air, the copper, and I am very patient when i'm tacking it in. Sometimes like I said, I get booger welds, really shitty penetration, and a huge pile of weld ontop.
    Thanks again for all the help
    Dec 2004
    In the paint boof
    14,256
    What type of welding are you doing? Patch panels? Are you doing a stright butt joint, butt with backer, or lap joint?
    Twister Racing 2k13
